ERROR
When adding connectivity rules to a geometric network, the following error is returned:"Failed to add the rule to the geometric network
The connectivity rule is invalid/malformed
The subtype code does not exist. [feature class name]"
The error is caused by trying to add more than 64 junction subtypes to a particular edge-edge connectivity rule.
This error results from a known issue in ArcGIS.
There is no workaround for this issue.
Install the ArcGIS 9.3.1 SP2 QIP Geodatabase Patch for 9.3.1 or use ArcGIS 10.1 SP1.
Article ID:000011580
Get help from ArcGIS experts
Download the Esri Support App
