ERROR
Failed to add data, unsupported data type. <shapefile>.shp
Error Message
When adding a shapefile to a map in ArcGIS Pro using the Add Data function, the following error message is returned:
Error:
Sample image of the error message in ArcGIS Pro
Adding the same shapefile in ArcMap returns the following error messages:
Error:
Error opening feature class.
Error:
Could not add the specified data object to the map.
Sample image of the first error message in ArcMap
Sample image of the second error message in ArcMap
Cause
This issue occurs if a shapefile is missing the necessary supporting files. As stated in ArcGIS Help: Shapefile file extensions, a shapefile cannot be displayed in any ArcGIS platform without the required supporting files.
For a shapefile to work, the following files must exist in the same folder location:
  • The .shp file, which contains the geometry for the shapefile.
  • The .shx file, which contains the shape index.
  • The .dbf file, which contains the attribute data.
Many shapefiles also have optional supporting files such as .prj (projection), .xml (metadata), .sbn and .sbx (spatial index), etc.
Solution or Workaround
When copying or moving a shapefile, ensure the required supporting files stated above are copied or moved along with it. It is recommended to copy or move a shapefile using ArcCatalog or a geoprocessing tool. For more information on moving a shapefile using a geoprocessing tool, refer to ArcGIS Help: Geoprocessing considerations for shapefile outputs.
Article ID:000019952
Software:
  • ArcGIS Pro
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
