ERROR
In ArcGIS Pro, attempts to add a feature layer to a map from Portal for ArcGIS fail with the following error message returned:
Error: Failed to add data: <Service URL>
Ensure the ArcGIS Server service is running before adding the feature layer to the map
Start the service in ArcGIS Server Manager. Refer to ArcGIS Server: Start a service in Manager for instructions. If the service is running in ArcGIS Server Manager, stop and start the service.
Repair the broken feature layer's data source in ArcGIS Pro
Ensure the layer's source is not broken, which is indicated in the Contents pane with a red exclamation point icon
next to the layer. Repair the broken data sources for the layer if it cannot be added to the map. Refer to ArcGIS Pro: Repair broken data sources for layers and tables for more information.
Article ID: 000027822
Get help from ArcGIS experts
Start chatting now
