ERROR
Failed to add data: <data name> Access denied [<data name>]
First Published: December 1, 2020
Last Published: April 9, 2021
Error Message
In ArcGIS Pro, data from a file geodatabase can be added to a map. In some instances, attempting to do so fails and returns the following error message:
Error:
Cause
This issue occurs if the data added is stored in a licensed file geodatabase. By design, data stored in a licensed file geodatabase is accessible when the license (.sdlic) file of the file geodatabase is added to ArcGIS Pro.
Solution or Workaround
Use the workflow below to add the .sdlic file to ArcGIS Pro to enable adding the data from the licensed file geodatabase. In this example, the Roads feature class is stored in the Housing_Project licensed file geodatabase.
If the .sdlic file is unavailable, request the file geodatabase creator to generate it. Refer to ArcGIS Pro: Generate a license file for more information. An administrator or a member with licensing privileges is required to perform the following workflow.
  1. In ArcGIS Pro, open a new map or the project containing the map. Refer to ArcGIS Pro: Open a project for more information.
  2. On the ribbon, click the Project tab.
  3. Select Licensing, and click Manage your data licensing.
  4. In the Manage Data Licenses dialog box, click Add.
  5. Navigate to the .sdlic file, and double-click the file to add it to the license list in the Manage Data Licenses dialog box.
Add the .sdlic file by double-clicking the file to add it to the license list.
  1. Click OK. In this example, the Housing_Project.gdb license file is added.
Click OK to add the Housing_Project.gdb license file.
  1. Add the data to the map. Refer to ArcGIS Pro: Add layers and layer packages to a map for more information.
The Roads feature class is successfully added to the map, as shown in the image below.
The Roads feature class is successfully added to the map and is displayed.
Article ID: 000024743
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
