ERROR
Failed to add attribute index in field . General Function Failure
Error Message
Applying an index to a shapefile or dbase file in ArcCatalog returns:
"Failed to add attribute index in field <aFieldName>.
General function failure"
Cause
The shapefile and dbase file have read-only permissions. Attribute indexes cannot be created for shapefiles or dBASE files that are read only.
Solution or Workaround
  • If the data is local, change the permissions for the shapefile or dbase file.
    A. Start Windows Explorer.
    B. Navigate to the shapefile
    C. Select the files associated with the shapefile (SHP, DBF, SHX, PRJ, SBN, SBX).
    D. Right-click and select Properties.
    E. Uncheck the Read-Only option.
    F. Click Apply and OK.
  • If the data is remote, have your system administrator change the file permissions.
Article ID:000002948
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
