ERROR
While running the sdegroup command for large featureclasses, the following error occurs if workstation memory allocation is exceeded:
"Error: Fail to allocate points array
A.n¦o
Rolling back last traner.(1)
Error: Operation Failed (1).
Error: Cannot Populate Target Layer."
If a recorded tile has a very large number of records, the memory allocation (realloc) could exceed the maximum limit, causing the process to fail.
There are no programming issues with this command that cause this error, rather, it is purely the lack of enough memory in the user machine.
Article ID:000010208
Get help from ArcGIS experts
Download the Esri Support App
