ERROR
Export SOE Error: org.eclipse.osgi.internal.framework.ContextFInder cannot be cast to java.net.URLClassLoader
Error Message
The Export SOE/SOI tool in Eclipse fails to export a Java SOAP SOE at version 10.7 and 10.7.1, with an error:
 “org.eclipse.osgi.internal.framework.ContextFInder cannot be cast to java.net.URLClassLoader”.
The error message appears as follows:
Cause
This error only occurs when a SOAP SOE is exported, due to an Eclipse SOE/SOI plugin issue. The Export SOE/SOI tool in Eclipse still works when a REST SOE is exported.
Solution or Workaround
The command-line tool soepackager can be used to export the SOE and generate the .soe file. You must first export the Java SOAP SOE project to a JAR file, and then execute soepackager from command, as follows:
  1. In Eclipse, right-click the Java SOAP SOE project and select Export.
  1. In the Export wizard, select Java > JAR file. Click Next.
  1. In the JAR Export wizard, ensure that all the SOAP SOE Java classes are checked. Define the export destination for the JAR file. Click Finish.
  1. The project is exported to a JAR file successfully. Execute the soepackager tool.
  • If the SOAP SOE is built with ArcGIS Enterprise SDK, use the EnterpriseSDK tool (by default located at C:\Program Files\ArcGIS\EnterpriseSDK\Java\tools\soepackager).
  • If the SOAP SOE is built with ArcObjects, use the ArcObjects tool (by default located at C:\Program Files (x86)\ArcGIS\DeveloperKit10.7\java\tools\soepackager).
    The following parameters can be used:
For ArcGIS Enterprise SDK:
soepackager_ent.bat -p [path to the jar file exported from step 3] -o [path to output folder] -j [path to the JDK] [optional parameters]
  For ArcObjects:
soepackager.bat -p [path to the jar file exported from step 3] -o [path to output folder] -j [path to the JDK] [optional parameters]
More details about this tool can be found at ArcGIS Enterprise SDK Help.
For example, executing the following command produces the results shown in the screen:
C:\Program Files\ArcGIS\EnterpriseSDK\Java\tools\soepackager>soepackager_ent.bat -p C:\temp\simplesoapsoe\simplesoapsoe_ent.jar -o C:\temp\simplesoapsoe -j "C:\Program Files\java\jdk1.8.0_201"
In this way, the Java SOAP SOE can be exported properly and the generated .soe file can be deployed to ArcGIS Server.
Article ID:000021108
Software:
  • ArcObjects SDK for the Java Platform
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
