ERROR
Error transferring https://<organization portal URL> - server replied: Not Found (203)
First Published: May 10, 2023
Last Published: July 6, 2023
Error Message
When adding a connection URL for ArcGIS Survey123 Connect, the following error message is returned:
Error:
The error message, Error transferring <host name>.<domain> - server replied Not Found (203) is returned.
Cause
The URL input in the ArcGIS connection URL box is incorrect. For example, after upgrading ArcGIS Enterprise, the name configured for the new Web Adaptor does not match the older version, returning the error above. This issue can also arise when copying and pasting the URL from the Portal for ArcGIS home page into the ArcGIS connection URL box, as the URL contains '/home'. Refer to ArcGIS Survey123: Setup and ArcGIS Enterprise: Installation requirements for more information.
Solution or Workaround
Use the correct URL
Ensure the URL is correctly typed into the ArcGIS connection URL box before clicking Add. Refer to the code block below for the correct URL format.
https://<webadaptorhost>.<domain>.com/<webadaptorname>/
Article ID: 000030497
Software:
  • ArcGIS Survey123 Connect
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
