ERROR
Error Saving Object An error occured trying to save the object named "<Output_Name>"
First Published: May 6, 2016
Error Message
In some instances, when exporting data to a shapefile, or attempting to convert graphics into features in ArcMap, the following error message is returned:
Error:
Error Saving Object
An error occured trying to save the object named "<Output_Name>".
Error Saving Object An error occured trying to save the object named "Output_Name".
Cause
The error occurs due to one of the following reasons:
  • Saving a feature class to a folder other than a geodatabase (.gdb).
  • Saving a shapefile to a .gdb.
Solution or Workaround
Select one of the following options to resolve this issue:
Specify a geodatabase output location when exporting data as a feature class
When saving data as a feature class, select File and Personal Geodatabase feature classes as the output file type and, specify a .gdb as the output location.
The Saving Data window displaying the output location when saving as a feature class in a geodatabase.
Specify a non-geodatabase folder output location when exporting data as a shapefile
When saving data as a shapefile, select Shapefile as the output file type, and specify a non-geodatabase folder as the output location.
The Saving Data window displaying the output location when saving a feature as a shapefile in a local folder.
Article ID: 000012804
Software:
  • ArcMap
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
