ERROR
Error opening convert file
Error Message
This error occurs while attempting to geocode using the Geocoding Developer's Kit:"Error opening convert file"
Cause
You are using an older us_addr.pat and/or us_intsc.pat file from ArcView 2.1.
Solution or Workaround
If you are working with the us_addr.pat and us_intsc.pat files because you had made pattern file edits from the Geocoding Developer's Kit, you need to re-edit these files.
  1. Remove the following four lines.
    \POST_START
    SOUNDEX {SN} {XS}
    RSOUNDEX {SN} {XR}
    \POST_END
  2. Re-encode the files using ENCODPAT as directed by the Geocoding Developer's Kit. All of the other pattern edits will work fine.
Article ID:000004069
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
