ERROR
Various ArcInfo commands that used to work with IMAGINE format images are now returning errors similar to:
***ERROR NUMBER 147 IN FUNCTION edll_Open***
>>>/san9/imagine8.3/830/usr/lib/archm/RasterFormats/img.dll: dlopen error: [ld.so.1:/net/prodinstall/prodinstall1/arcinfo/arcinfo_802/arcexe80/bin/arcedit: fatal:/san9/imagine8.3/830/usr/lib/archm/RasterFormats/img.dll: open failed: No such file or directory]<<<
An IMAGINE_HOME variable is being explicitly set with a path to an IMAGINE install location.
IMAGINE_HOME is always implicitly taken by Workstation as $ARCHOME/raster, and the IMAGINE libraries installed with Workstation expect a directory hierarchy under IMAGINE_HOME, which can be found in $ARCHOME/raster. Therefore, setting a new IMAGINE_HOME will only work if the same directory hierarchy is maintained.
ArcInfo Workstation does not require the IMAGINE_HOME variable to be set.
Article ID:000002630
Get help from ArcGIS experts
Download the Esri Support App
