ERROR
"Error in opening workspace" returned when creating a hosted feature layer in Portal for ArcGIS
First Published: October 6, 2022
Last Published: October 6, 2022
Error Message
Portal for ArcGIS allows creating hosted feature layers by publishing feature layers from ArcGIS Pro or files in a portal to ArcGIS Enterprise. However, after updating the Portal for ArcGIS and ArcGIS Server licenses, attempts to create a hosted feature layer in Portal for ArcGIS fail, and return the following error message:
Error:
Error in opening workspace.
Cause
The ArcGIS Data Store license does not match the Portal for ArcGIS and ArcGIS Server licenses.
Solution or Workaround
Use the following steps to resolve the error and match the ArcGIS Data Store license to the Portal for ArcGIS and ArcGIS Server licenses.
  1. On the Portal for ArcGIS machine, open Command Prompt.
  2. In the Command Prompt window, type the following command:
cd <ArcGIS Data Store installation directory>\datastore\tools
  1. Type updatelicense, and press the Enter key.
The directory and the syntax used in the Command Prompt window
This workflow updates the ArcGIS Data Store license to match the Portal for ArcGIS and ArcGIS Server licenses.
Article ID: 000028416
Software:
  • ArcGIS Data Store
  • Portal for ArcGIS
  • ArcGIS Server
Get support with AI
Start chatting now
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
