ERROR
Error in Filename
Error Message
This error occurs when setting the Geocode Data Path:"Error in Filename. Please verify that the correct path & filename are given."
Cause
The message happens when setting the path and the U.S. Address Finder CD-ROM is not in the CD drive.
Solution or Workaround
  1. Make sure the U.S. Address Finder CD-ROM is in the CD drive and start Atlas.
  2. Click File > Preferences and select the Directories tab.
  3. Set the Geocode Data Path to the following:
    <cdrom_drive>:\
    Be sure the letter of the CD drive is correct.
    If you are geocoding by ZIP, it is not necessary to have the U.S. Address Finder CD-ROM loaded. Set the Geocode Data Path to the GEOCODE folder in AtlasGIS. This folder contains files that are accessed when Geocoding by ZIP.
Article ID:000001988
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
