ERROR
Error in file [pathname.rpt]: Invalid export DLL or export format.
Error Message
Using ArcView's Report Writer extension to create a report through a Citrix client causes the following error:
"Unable to create report:
Command line: [pathname.rpt],[pathname.dbf],[report type]
Error: Error in File [pathname.rpt]:
Invalid export DLL or export format."
Cause
Citrix limits the access to files on the server. This restriction forces ArcView and Crystal Reports to look for necessary DLLs in the user's \Windows directory. However, these DLLs are installed under the system's \WINNT\Crystal directory.
Solution or Workaround
Copy the Crystal folder located in the terminal server's \WINNT directory to each user's %homedirectory%\Windows folder.
Article ID:000005983
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
