ERROR
When exporting a layer to an SDE database with the 'Use the same Coordinate System as the data frame' option, ArcMap returns ths message:"Error: Error exporting data. Spatial index too small[out class name]."This message is followed by two additional messages:"ArcMap Warning: Some records may not have been exported correctly""Export Layer Data: There was an error exporting the layer"
Although ArcMap uses coordinates of the data frame, it uses the spatial grid associated with the data. This may cause an inadequate grid size when exporting. For example, exporting a layer stored in geographic coordinates exported from a data frame in a UTM projection will produce an error message.
Article ID:000004447
Get help from ArcGIS experts
Download the Esri Support App
