ERROR
Error Code: 1050 AXLParser: Fatal error at line
Error Message
When performing certain transactions in an ArcIMS website, the following error is returned:
Website popup alert  AXLParser Fatal error
Here are other examples of this error, as recorded in the ImageServer log file:
Code:
<ERROR machine="YOURSERVER" processid="1184" threadid="1400">AXLParser: Fatal error at line 823, column 9. Message: Expected end of tag 'POLYGON'</ERROR><ERROR machine="YOURSERVER" processid="1184" threadid="1400">AXLParser: Fatal error at line 330, column 8. Message: Expected an attribute name</ERROR><ERROR machine="YOURSERVER" processid="1184" threadid="1872">AXLParser: Fatal error at line 498, column 12. Message: Expected end of tag 'OBJECT'</ERROR><ERROR machine="YOURSERVER" processid="1184" threadid="1400">AXLParser: Fatal error at line 637, column 2. Message: A '<' character cannot be used in attribute 'coords', except through <</ERROR><ERROR machine="YOURSERVER" processid="1184" threadid="1872">AXLParser: Fatal error at line 647, column 149. Message: Unterminated start tag, 'SIMPLEMARKERSYMBOL'</ERROR><ERROR machine="YOURSERVER" processid="1616" threadid="580">AXLParser: Fatal error at line 442, column 46. Message: Expected equal sign</ERROR>
Cause
If the following are being used:
· Microsoft's Internet Information Server (IIS)
· Apache Tomcat 5.0.2x servlet engine
· a file called isapi_redirector2.dll in the $CATALINA_HOME\bin\win32 directory
It is then highly likely that this DLL file is causing the problem. It is not correctly passing the ArcXML request received by IIS to the ArcIMS Servlet Connector.
Solution or Workaround
It is necessary to remove the isapi_redirector2.dll and replace it with the updated isapi_redirect.dll file. Refer to link in the Related Information section below. the ESRI Knowledge Base Technical Article 29766; the link is provided in the "Related" section below.
    Article ID:000008133
    Software:
    • Legacy Products
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Related Information
    Discover more on this topic
