ERROR
Error attribute column not found
Error Message
This problem is addressed in ArcGIS 8.1 Service Pack 1. See Related Information section to download this pack.Using 'sdetable -o create_view' returns this error:"Error attribute column not foundThe message does not specify the missing column name.
Cause
You entered an invalid column name with the 'sdetable create_view operation.'
Solution or Workaround
  1. Use the 'sdetable describe' operation to list the columns of the tables referenced by the view.
  2. Check this list to determine which column does not exist or is misspelled.
Article ID:000003590
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
