ERROR
ERROR 999999: Error executing function. Invalid Topology [Maximum tolerance exceeded.]
Error Message
When running the Dissolve tool in ArcMap, the operation does not complete and the following error message is returned:
Error:
Cause
As each feature class has unique sizes and scales, the default x,y tolerance settings may be unable to accommodate the size and scale of the data. This causes the error to be returned as the data has reached the maximum tolerance x,y tolerance setting.
By default, the tolerance setting is set to 0.001 meters or its equivalent in map units. This setting is 10 times the default resolution value and is the recommended settings for most cases. Different tolerance values produce different results for relational and topological operations. Higher tolerance values result in lower accuracy for coordinate data, while smaller tolerance values result in a higher level of accuracy.
Additionally, large feature classes with small scale sizes are very detailed; thus, the likelihood of reaching the maximum x,y tolerance level is greater.
Solution or Workaround
The following steps allow users to customize the maximum x,y tolerance limit of the Dissolve tool, through the Environments settings:
  1. In the Catalog pane, navigate to System Toolboxes > Data Management Tools > Generalization > Dissolve.
  2. Click Environments.
    [O-Image]
  3. Expand XY Resolution and Tolerance. Set the XY Tolerance to a suitable value (such as 0.001 or 0.01) based on the size and scale of the dataset. Use the drop-down option to select the measurement unit. Click OK.
    [O-Image]
Article ID:000012883
Software:
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
