ERROR
ERROR 30024: Solve returned a failure. "Stops" does not contain valid input for any route. Failed to execute (Solve).
Error Message
When running a route analysis using Network Analyst either in ArcGIS Pro or ArcMap, if a start time is specified and the Stops are in different time zones while the travel setting is not set to Preserve First Stop, the following error message is returned:
Error:
Additionally a warning message is included indicating:
Warning:
Location "Location #" in "Stops" is in a different time zone from location "Location #". The time zone for the route start time is thus ambiguous since the first stop is not being preserved.
Image of the error message
Cause
This error occurs as the network is unable to determine which time zone to use for the specified start time because the Stops are in a different timezone. As stated in the warning, the timezone for the route start time becomes ambiguous as the first stop is not being preserved.
Solution or Workaround
To resolve this issue, select one of the following solutions depending on the platform used:
ArcGIS Pro
To preserve the first stop
  1. In ArcGIS Pro, select the route layer in the Contents pane.
  2. On the ArcGIS Pro ribbon, click the Network Analyst tab.
  3. Click the Route tab.
  4. Look for Sequence: and click the drop down menu.
  5. Click Preserve First Stop.
Image of the ArcGIS Pro Ribbon
ArcMap
In ArcMap,the Preserve First Stop setting is located in the Layer Properties of the route analysis layer.
  1. In ArcMap, select and right-click the route layer.
  2. From the context menu, select Layer Properties.
  3. In the Layer Properties window, click Analysis Settings.
  4. Under the Settings sections, check the Preserve First Stop checkbox
  5. Click Apply, then click OK.
Image of the Layer Properties window
Article ID: 000021554
Software:
  • ArcGIS Business Analyst Pro
  • ArcMap
  • ArcGIS StreetMap Premium
  • ArcGIS Business Analyst Desktop
  • ArcGIS Pro 2 x
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
