ERROR
Note: The content in this article pertains to ArcGIS versions 8.x and 9.x only. Later versions of ArcGIS may contain different functionality, as well as different names and locations for menus, commands and geoprocessing tools.
When installing from an ESRI product CD-ROM, the following error message may occur:
"Error 1305: Error reading from file."
This may prevent the installation from completing, as well as causing an installation roll-back.Depending on the version of Installer, the "Error 1305" may or may not appear.
There are several conditions that cause this error:
The following procedure steps should help alleviate this problem. Please refer to Microsoft's Knowledge Base in the Related Information below for more information.
Note: One shortcut that may be available is to copy the entire contents of the installation CD on to the local hard drive of the target installation computer then install the software from the copy. This may not work if the CD-ROM is too badly damaged or if another CD-ROM drive is not available, etc., however, it may help decrease the troubleshooting time if the installation needs to be completed quickly.
Article ID:000007734
Get help from ArcGIS experts
Download the Esri Support App
