ERROR
Error 13: Type mismatch
Error Message
[O-Image] Singapore
This article was contributed by Esri Singapore.VBA code that was created in ArcGIS 9.3 may return the following error in ArcGIS 10. "Error 13: Type mismatch"
Cause
When code created with ArcGIS 9.3 contains the following lines and is run in ArcGIS 10, a mismatch error is returned.
Code:
Public Sub Run()
Dim pMxDoc As IMxDocument
Set pMxDoc = ThisDocument
Dim pPageLayout As IPageLayout
Set pPageLayout = pMxDoc.PageLayout
Dim pPage As IPage
Set pPage = pPageLayout.Page '** error occurs here **
End Sub
Solution or Workaround
  1. Verify that the references to the esriCarto and esriCartoUI libraries have been given from Tools > References in the VB editor.
    They should be pointing to '<ArcGIS installation folder>\com\esriCarto.olb' and '<ArcGIS installation folder>\com\esriCartoUI.olb', respectively.
    If needed, correct the library references to these paths (default setting).
  2. If the error continues to occur after verifying the reference libraries, fully qualify the interfaces in the code.
    Code:
    Dim pPageLayout As esriCarto.IPageLayout
    Set pPageLayout = pMxDocument.PageLayout
    Dim pPage As esriCarto.IPage
Article ID:000011449
Software:
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
