ERROR
"Error 001992: Dataset must be versioned." When running a trace on a branch versioned utility network feature service in ArcGIS Pro
First Published: April 28, 2025
Last Published: August 5, 2025
Error Message
Running a trace on a branch versioned utility network feature service in ArcGIS Pro, returns the error:
This same feature service can successfully run a trace in Portal's Experience Builder.
Cause
This is due to the Version Management capability not being checked.
Solution or Workaround
Before publishing the utility network as a feature service, ensure the Version Management capability is checked.
This cannot be checked once the feature service is published.
Article ID: 000034849
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
