ERROR
In ArcGIS Pro, it is possible to create and assign a domain to a field from the Fields view. After creating a domain in the Fields view, the new domain is automatically selected, and attempts to save further edits fail. The following error message is returned:
Error: ERROR 000356: Invalid domain type.
In this example, after creating the Manager field and the Manager_Names domain in the Fields view, the domain is automatically selected for the field, but attempting to save the table fails. Hovering the cursor over the red box to the left of the field's Visible column check box displays the error message, as shown in the image below.
This issue occurs if the data type of the domain and the field is not the same. The image below shows the Manager_Names domain has a long integer data type.
To resolve the issue, use the workflow below to create and assign a new domain with a data type that matches the field.
Note: The options listed in the drop-down menu for creating a new domain vary depending on the field’s data type.
in the Domains view.
Article ID: 000025235
Get help from ArcGIS experts
Start chatting now
