ERROR
ERROR 000210: Cannot create output <value>. Failed to execute (ExportRules)
Last Published: February 25, 2022
Error Message
Attempting to export a utility network rule, such as a connectivity or structural rule, using the Export Rules (Utility Network) tool fails in ArcGIS Pro, with the following error messages returned:
Error:
Error:
Failed to execute (ExportRules).
Cause
  • The known causes of the first error message returned are described in the article, ArcGIS Pro: 000210: Cannot create output <value>.
  • The second error message is returned because the .csv extension is not included in the output CSV file name when exporting the rule.
Solution or Workaround
In Step 5 of the article, ArcGIS Pro: Export network rules to a CSV file, include the .csv extension in the output CSV file name for the Output File parameter.
Article ID: 000027261
Software:
  • ArcGIS Utility Network
  • ArcGIS Pro 2 8 x
  • ArcGIS Pro 2 7 x
  • ArcGIS Pro 2 x
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
