ERROR
ERR0125, ERR0513: ArcMap Server (Unix) Error when trying to administer Service
Error Message
When adding an ArcMap Service, ArcIMS returns the following messages:"[ERR0125] Error when trying to administer Service.""[ERR0513] Data for layer with name <layername> and ID "x" of dataframe <dataframe name> is not found. Service <service name> cannot be created."
Cause
The data used in the map document is not accessible.
Solution or Workaround
Follow the steps below.
  1. Verify if the layer reported in the error message contains a broken data path.
    If using ArcSDE based data, verify if the server is running and the layer used in the map is accessible.
    If using file based data, verify the data is available and there is read permission for the ArcIMS user to access the data.
  2. Verify that the layer reported in the message does not use any unsupported data type. For example: Personal Geodatabase.
  3. Verify all path names to the data do not contain any capitalization or special characters. ArcMap server on Unix will accept only lower-case path names to the data.
  4. All file names are case sensitive. Verify the data name specified for a layer in the map matches with the file name of data residing on Unix.
  5. Check to see the MXD/PMF does not contain Windows path names to the data.
  6. Verify that the map document does not use relative paths to the data.
    Maps using relative paths to data will work with ArcReader on Unix, but ArcMap server will not be able to access data referenced by relative paths.
Article ID:000006881
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
