ERROR
ERM009: Could not get value IMAGINE_HOME under the HKLM registry key: SOFTWARE\ESRI\Raster\Environment
Error Message
During the install or uninstall of the ER Mapper ECW plug-in, the following message is displayed: "ERM009: Could not get value IMAGINE_HOME under the HKLM registry key: SOFTWARE\ESRI\Raster\Environment.
Please refer to the readme.txt and contact support."
Cause
The ECW plug-in install and removal requires registry keys which are no longer present or created by ArcGIS 9.2.
Solution or Workaround
For assistance with the ECW plug-in support, please contact ERMapper.
ArcGIS 9.2 natively supports ECW reading and also compresses images with JP2 compression. The ECW plug-in is no longer required to perform these functions in ArcGIS 9.2.
    Article ID:000009099
    Software:
    • ArcMap
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Related Information
    Discover more on this topic
