ERROR
Edit operation failed. The table is not multiversioned
Last Published: July 18, 2025
Error Message
In ArcGIS Pro, when attempting to edit a feature layer within a versioned feature dataset in an enterprise geodatabase, the process fails and returns the following error message:
Error:
The table is not multiversioned.
The Edit operation failed error message
Cause
The versioned feature dataset contains non-versioned feature layers or feature classes.
Solution or Workaround
Remove non-versioned feature classes within the versioned feature dataset
When working with a feature dataset that is registered as versioned, all feature classes and feature layers contained within it must also be registered as versioned. Remove any non-versioned feature layers or feature classes from the versioned feature dataset prior to performing edits.
Re-registering the feature dataset as branch versioned using geoprocessing tool
  1. Open the project in ArcGIS Pro.
  2. Unregister all feature layers or feature classes within the versioned feature dataset using the Unregister As Versioned tool. Refer to ArcGIS Pro: Unregister As Versioned (Data Management) for additional information.
  3. Register all feature layers or feature classes within the feature dataset using the Register As Versioned tool. Refer to ArcGIS Pro: Register As Versioned (Data Management) for additional information.
Article ID: 000036398
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
