ERROR
Domain: com.esri.arcgis.runtime.error Code: 3054 Description: The item to be created already exists in the database
First Published: August 14, 2019
Error Message
When working on ArcGIS Online hosted feature service layers in Collector for ArcGIS with an iOS (Aurora), the layers do not draw, and a warning message appears on the layer list indicating "The layer could not be loaded". A click on the warning returns the following error message:
Error:
Code: 3054
Description: The item to be created already exists in the database.
Cause
The problem occurs due to an issue with the domain as stated in the error message. The domain field type does not match the assigned field. In this case, a domain with the short integer type is assigned to a double field type.
Solution or Workaround
To resolve this issue, the X-Ray for ArcCatalog add-in is required.
  1. Click here to download the X-Ray for ArcCatalog add-in, and add it to ArcCatalog.
  2. Download the problematic data to the machine as a file geodatabase.
  3. In ArcCatalog, click Customize > Extensions....
  4. Check the X-Ray Extension for Geodatabases check box.
Image of enabling the add-in
  1. In the X-Ray for Geodatabases pane, click Tools > Replace Field....
  2. In the Replace Field window, for Input Table/Feature Class, select the input dataset.
  3. For Existing Field Name, select the field with the conflicting data type. Input a new field name, and ensure Field Type is the same as the domain's.
  4. Click OK and republish the hosted feature service layers to ArcGIS Online.
Article ID: 000021709
Software:
  • ArcGIS Collector
  • ArcGIS Online
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
