ERROR
Do not support "SRPE: SDTS RASTER PROFILE and EXTENSIONS"
Error Message
An error occurs when running the STDSIMPORT command either from the command line or from the wizard:STDSIMPORT 1015 newgrid
Importing ARC coverages newgrid from SDTS/TVP transfer 1015 IDENTIFICATION::
Standard Identification . : SPATIAL DATA TRANSFER STANDARD
Standard Version. . . . . : 1998 JUNE 9
Standard Documentation Ref: ANSI NCITS 320-1998
Profile Identification. . : SRPE: SDTS RASTER PROFILE and EXTENSIONS
Do not support "SRPE: SDTS RASTER PROFILE and EXTENSIONS".
Unable to create arc coverage d:\workspace\newgrid
Bailing out of CONVSDTS
Cause
Non-compliant changes in the SDTS format between July 2001 and October 2001 were released to the public. See USGS Data link in the Related Information section.
Solution or Workaround
  1. Download SDTS2DEM.EXE from the GIS Depot site. See Related Information below.
    This executable was not created by ESRI and is not supported by ESRI in any way.
  2. Run the executable to convert the SDTS file to DEM.
    Code:
    Usage: sdts2dem [-n] [DDFbase] [DEMbase] [cell_id]
    -n: put newlines at end of 1024-char line [default is NO newline].
    DDFbase: first 4 chars (ABCD) in DDF file name (ABCDxxxx.ddf)
    DEMbase: file name for output without .DEM extension
    cell_id: characters in position 7 and 8 of CELL file name (usually 'L0')
  3. Use the DEMLATTICE or DEMGRID command in ArcInfo Workstation, or the 'DEM to GRID' tool in ArcToolbox.
    The latest information and compliant DEM files can be found at USGS SDTS Format description page. See link below.
Article ID:000004563
Software:
  • ArcMap 8 x
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
