ERROR
Directory pathname too long
Error Message
When executing the REGIONPOLY command and specifying an {out_table}, the conversion does not complete and this message is returned:
Cause
The REGIONPOLY atool has a limit when using the {out_table}, where the (length of the full path to the current workspace) + (the length of the subclass name) + 13, cannot be greater than 79 characters.
Solution or Workaround
Copy the coverage to a new workspace that will yield a shorter path.
You can use AML to determine the character length of the path:
Code:
Arc: workspace
Current location: e:\data\coverages
Arc: &type [length [show &workspace]]
17
Article ID:000002359
Software:
  • Legacy Products
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
