ERROR
DeleteNonTaggesElements
Error Message
When editing a Geodatabase Annotation Feature Class, the following error message occurs:
"DeleteNonTaggesElements
Object doesn't support this action."
Cause
Having the National Geographic Topo! extension installed causes this error message. If the extension is installed on the computer but unchecked in ArcMap, it is still detected by ArcMap, and the above error message is returned. This can occur when either setting the active annotation layer or adding new labels in ArcMap.
Solution or Workaround
Currently, the only solution to this error is to uninstall the Topo! extension.
Article ID:000006449
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
