ERROR
ArcGIS Pro: Delete Selected Features failed. The selection contains no editable features
Last Published: January 30, 2026
Error Message
When attempting to delete a feature in ArcGIS Pro, the following error message is returned:
Error:
The selection contains no editable features. - No edits producing database changes were found.
The error message
Cause
  • The annotation feature is not compatible with the current ArcGIS Pro version because the schema of the annotation feature is not upgraded to the current ArcGIS release.
  • The data's coordinate system is undefined. Editing data with an undefined coordinate system is not supported in ArcGIS Pro.
  • The feature dataset is read-only and not editable. For example, geometric networks and CAD feature datasets are not editable in ArcGIS Pro.
  • Editing a Hosted Feature Layer and the user has the role Viewer
Solution or Workaround
Depending on the circumstance, the workarounds described below are applicable.
Use the Upgrade Dataset tool
Upgrade the annotation feature using the Upgrade Dataset tool. Refer to ArcGIS Pro: Upgrade Dataset (Data Management) for instructions and more information.
Use the Define Projection tool
Use the Define Projection tool to define a coordinate system for the data. Refer to ArcGIS Pro: Define Projection (Data Management) for instructions and more information.
Use ArcMap to delete features
To delete features from a geometric networks dataset, use ArcMap. Refer to ArcMap: Deleting a feature for instructions and more information.
Convert CAD data to GIS data
Convert the CAD data to GIS Data. Refer to How To: Convert CAD data to GIS data in ArcGIS Pro for instructions.
Update user role
Deleting features from a Hosted Feature Layer requires a user role that has editing capabilities (not Viewer).
Article ID: 000032283
Software:
  • ArcGIS Pro 3 1
  • ArcGIS Pro 3 0
  • ArcGIS Pro 3 2
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
