ERROR
Datum check in appending XML file failed
Error Message
When appending a cadastral XML file from one parcel fabric to another parcel fabric, the following error is returned. “Datum check in appending XML file failed”
[O-Image]
Cause
The projections of the parcel fabrics do not match.
Solution or Workaround
Use the Project tool to project the feature dataset containing the parcel fabric into the same projection as the target parcel fabric.
  1. Navigate to Data Managment Tools > Projections and Transformations > Feature.
  2. Save the cadastral XML file of the projected source fabric.
  3. Begin an editing session on the target fabric, and append the new cadastral XML file.
Article ID:000011866
Software:
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
