Error Message
While trying to connect to a SQL Server database in ArcGIS Pro, the connection fails with the following error:
“Database Connection: Failure to access DBMS server”
This typically indicates that ArcGIS Pro cannot establish communication with the SQL Server database.
Cause
This error may occur due to:
- Incorrect SQL Server name or instance
- Network connectivity or firewall restrictions
- SQL Server service not running or inaccessible
- Incorrect database username or password
- Incorrect authentication type selected
Solution or Workaround
- Verify the SQL Server name/instance is correct, for example,
SERVERNAME or SERVERNAME\INSTANCE, and check for typographical errors. - Confirm the SQL Server service is running or contact the database administrator to verify the server is online.
- Re-enter and validate database login credentials (username and password).
- Verify the authentication type selected in ArcGIS Pro is correct (Database Authentication or Operating System Authentication) based on the database configuration.
- Confirm connection to the correct network/VPN and ensure the server is accessible.
- Re-create the connection in ArcGIS Pro:
- Go to Catalog > Databases > Add Database Connection
- Enter the connection details again and click Validate
