ERROR
Data source error
Last Published: September 15, 2021
Error Message
Embedded content in ArcGIS Dashboards does not function properly and only displays empty layers with the following error:
Error:
Data source error
Dashboard containing the Data source error as the items.
Cause
  • The hosted layer referenced in the dashboard is not shared with the specified user.
  • The hosted layer referenced in the dashboard is removed and re-added. This is expected behavior. While the layer may contain the same name, a newly created layer contains a different item ID. The dashboard recognizes the previous item ID, referencing items that no longer exist.
Solution or Workaround
Depending on the cause, use one of the following solutions to solve the issue.
Article ID: 000026417
Software:
  • ArcGIS Dashboards
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
