C:\WINDOWS\SYSTEM32\AUTOEXEC.NTThe system file is not suitable for running MS-DOS and Microsoft Windows applications
Error Message
Users may receive the following error message when starting ArcView setup:
Cause
The system is missing the file, AUTOEXEC.NT.
Solution or Workaround
Contact a systems administrator for assistance in rebuilding the AUTOEXEC.NT file. In many cases, a known good AUTOEXEC.NT can be copied from a working system. Once the file is replaced, ArcView will install normally.
