ERROR
Cross-Origin Request Blocked: The Same Origin Policy disallows reading the remove resource at https://<custom widget directory>/widget/manifest.json.
Error Message
When attempting to configure a custom widget in Web AppBuilder for ArcGIS in Portal for ArcGIS, clicking OK does not complete the configuration process. Instead, nothing happens, and the following error is returned in the web browser developer tools console:
Error:
Cross-Origin Request Blocked: The Same Origin Policy disallows reading the remove resource at https://<custom widget directory>/widget/manifest.json (Reason: CORS header 'Access-Control-Allow-Origin' missing).
Custom widgets are stored on a web server and are accessed through a web address.
Cause
This issue occurs when the response headers sent from Portal for ArcGIS cannot access the Java libraries storing the custom widgets.
Solution or Workaround
Follow the steps listed below to resolve the issue:
  1. Launch Internet Information Services (IIS) Manager.
  2. Navigate to the folder containing the custom widgets in IIS.
Image of the HTTP Response Header selection in Internet Information Services (IIS)
  1. Double-click HTTP Response Headers.
  2. Click Add.
Image of the Add selection in the HTTP Response Headers window
  1. Add the following entry:
Value: *
Image of the Add Custom HTTP Response Header window
  1. Click OK.
Article ID: 000019442
Software:
  • Portal for ArcGIS
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
