ERROR
Error creating this geodatabase. This application is not licensed to perform this operation
First Published: August 2, 2018
Error Message
With ArcGIS Server Workgroup, a workgroup geodatabase can be created using ArcMap and can be accessed by up to 10 users at a time. In some instances, when creating a workgroup geodatabase, the process fails and returns the following error:
Error:
Cause
The following are possible causes for this issue:
  • The SQL Server instance version is not compatible with the installed ArcGIS version.
  • The SQL Server instance is not authorized with an ArcGIS Server Workgroup license.
Solution or Workaround
Depending on the cause, select one of the options below to resolve this issue:
Article ID: 000017831
Software:
  • ArcGIS Desktop
  • ArcGIS Server
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
