ERROR
The following error message is displayed when creating a geodatabase on a Database Server in ArcCatalog:
Error:
Error creating this geodatabase
CREATE DATABASE failed. Some file names listed could not be created. Check related errors.
The database creation process is executed by SQL Server Express. This error often occurs because the account used to run SQL Server Express does not have permissions to the directory specified, for example, C:\ or D:\.
Note: The default name for the instance is SQL Server(SQLEXPRESS).
Warning: Ensure no one is connected before following these steps.
Note: ESRI installation documentation recommends that the Local System account be used to ensure system-wide permissions, however another account may be specified here if it has permissions to the necessary data directories.
Warning: Any users connected are disconnected and changes lost.
Article ID: 000008985
Get help from ArcGIS experts
Start chatting now
