ERROR
Create: An Unexpected failure occured. Underlying DBMS error CLI0100E ...
Error Message
After loading a layer using DB2's Spatial Extender Control Center, the following error message occurs when creating new features in a DB2 SDE geodatabase feature class:Create: An unexpected failure occurred.
Underlying DBMS error CLI0100E Wrong number of parameters.
SQLSTATE=07001::07001
Cause
Logic problems in calculating the bind parameter number for S_bind_column.
Solution or Workaround
Download ArcGIS 8.1 Service Pack 1.
Article ID:000004092
Software:
  • ArcMap 8 x
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
