ERROR
Could not edit the data in the folder or database you selected
Error Message
This article pertains to ArcGIS versions 8.x and 9.x. Later versions of ArcGIS may contain different functionality, as well as different names and locations for menus, commands and geoprocessing tools.
If a Geometric Network with a coordinate system that differs from Data Frame is added to ArcMap, the following error message appears:
"Could not edit the data in the folder or database you selected. Check to see that you have the appropriate permissions."
Cause
The coordinate system of the Geometric Network is different from the coordinate system of the Data Frame in ArcMap. Geometric Networks that have been projected 'on-the-fly' cannot be edited in ArcMap.
Solution or Workaround
Reset the Data Frame coordinate system in ArcMap to match the Geometric Network.
Article ID:000004780
Software:
  • ArcMap 8 x
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
