ERROR
Could not edit any of the map's layers
Error Message
If loading an unversioned feature class in ArcMap to attempt nonversioned editing, the following error message may display when editing:
"Could not edit any of the map's layers.
No data sources in the map are registered as versioned or you lack privileges to modify data sources which are registered as versioned."
Cause
By default, ArcMap edit sessions are set to perform versioned edits. This means that only data registered as versioned can be edited.
Solution or Workaround
To resolve the error, configure the current ArcMap session to perform nonversioned edits. Information on the steps for nonversioned editing can be found in the Related Information below.
Versioned tab setting required to enable nonversioned editing
[O-Image]
    Article ID: 000009906
    Software:
    • ArcMap
    Get support with AI
    Start chatting now
    Related Information
    Discover more on this topic
    Get help from ArcGIS experts
    Contact technical support
    Start chatting now
    Go to download options
