ERROR
Could not create the DBASE part of shapefile
Error Message
This error message may occur when using the MIFSHAPE utility:Could not create the DBASE part of shapefile
Cause
The mif file is located on the root directory. It needs to be placed in a subdirectory before running the conversion.
Solution or Workaround
  1. Copy the mif file into a subdirectory under the root directory. For example: c:\mifdata\sample instead of c:\sample.
  2. Run the utility as normal.
Article ID:000003054
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
