ERROR
Could not add the specified data object to the scene. Try using a smaller subset
Error Message
The following warning message is displayed when trying to add a terrain dataset to ArcScene."Could not add the specified data object to the scene. Try using a smaller subset."
Cause
Terrain datasets are not supported in ArcScene. Terrains are supported in ArcMap and ArcGlobe.
Solution or Workaround
To use a terrain dataset as an elevation source in ArcScene, the terrain data must be converted to a supported format using one of the following methods:
Article ID:000011396
Software:
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
