ERROR
Could not access any GIS Server machines. Please contact your system administrator
First Published: May 5, 2016
Last Published: July 2, 2026
Error Message
Accessing ArcGIS Server through ArcGIS Web Adaptor located in a perimeter network returns the following error:
Error:
Could not access any GIS Server machines. Please contact your system administrator.
Image of the error message
Cause
The following are possible causes for this issue:
  • Insufficient hardware resources on the server hosting ArcGIS Server may cause a loss of connectivity.
  • Windows Firewall rules do not allow access for ports 443 and 6443 on the ArcGIS Server machine.
  • Certificate name mismatch - common name (domain name) in the certificate does not match the address in the address bar of the browser.
  • ArcGIS Web Adaptor starts before ArcGIS Server, and is unable to establish a connection to the machine.
Solution or Workaround
The solutions provided are specific to each situation described above.
Article ID: 000012620
Software:
  • ArcMap
  • ArcGIS Server
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
