ERROR
CONNECT on Solaris to Oracle 8i fails with ld.so.1: /esri/arcexe81/bin/dbi_oracle: fatal: libjava.so: open failed
Error Message
When connecting to Oracle 8i from ArcInfo Workstation version 8.1.2 on Solaris, the following error occurs:
Code:
Arc> connect oracle username/password
ld.so.1: /esri/arcexe81/bin/dbi_oracle: fatal: libjava.so: open failed:
No such file or directory
Server ops, pid: 1234 terminated abnormally
Cause
The $ARCHOME/bin/dbi_oracle executable needs to link against the Oracle LIBJAVA.SO library when connecting.
Solution or Workaround
Add the path to the Oracle LIBJAVA.SO library to the user's $LD_LIBRARY_PATH variable. This library is located in the following directory:
/ora817/app/oracle/product/jre/1.1.8/lib/sparc/native_threads
    Article ID:000005040
    Software:
    • Legacy Products
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Related Information
    Discover more on this topic
