ERROR
Compile Error: User-defined type not defined
Error Message
When running VBA code within ArcMap or ArcCatalog that includes references to Network Analyst objects, you get the following error message when you attempt to run the code:
'Compile error: User-defined type not defined'
Cause
esriNetworkAnalyst.olb and esriNetworkAnalystUI.olb are not included in the VBA list of references.
Solution or Workaround
You need to include references to the Network Analyst OLB files.
  1. Within VBA, click on Tools > References to show the References dialog box.
  2. Check on the references 'ESRI Network Analyst Object Library' and 'ESRI NetworkAnalystUI Object Library'.
  3. Click OK to dismiss the dialog.
  4. Re-run the VBA code.
Article ID:000007854
Software:
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
