ERROR
When adding a shapefile layer to a MapObjects Java application, the following error is returned:
com.esri.mo.ui.bean.LayerNotFoundException: Layer could not be found (Mines_msc) at com.esri.mo.ui.bean.r.getLayer(Unknown Source) at com.esri.mo.ui.bean.Layer.getLayer(Unknown Source) at com.esri.mo.ui.bean.Map.addImpl(Unknown Source) at java.awt.Container.add(Container.java:228)
Two potential causes:
1) An incorrect path to the dataset has been specified.
2) MapObjects Java cannot read shapefile datasets that contain two or more fields where the first 10 characters are identical. This is a limitation imposed by the dBase III (dbf) definition associated with ESRI's proprietary shapefile format. Some applications (such as Arcview and ArcMap) have internal methods for handling dbf fields with more than 10 characters.
Article ID:000006131
Get help from ArcGIS experts
Download the Esri Support App
