ERROR
com.esri.cc.comp.Projectorg. xml .sax.SAXParseException: Document root element is missing
Error Message
Note: This issue was fixed in ArcIMS 9.1.Attempting to open a configuration file that was prevously edited in a text editor on Windows 2000 and saved as UTF8, results in the following error message being returned:
"com.esri.cc.comp.Projectorg. xml .sax.SAXParseException:
Document root element is missing"
Cause
The use of non-English characters within the configuration file causes this problem.
Solution or Workaround
Use an XML editor such as XML Spy or Xeena instead of a text editor to make changes to a configuration file that includes non-English characters.
Article ID:000006016
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
