ERROR
com.esri.arcgis.datastore.common.DataStoreException: Attempt to configure datastore failed.. Extended error message: Database upgrade failed.. Extended error message: Failed to start relational data store
Last Published: December 23, 2020
Error Message
In the ArcGIS Data Store Configuration wizard, attempting to configure a relational data store returns the following error on the Prerequisite Check page:
Error:
Image of the error message
Cause
The following are possible causes:
Solution or Workaround
To resolve this issue:
Warning:
The following solution wipes data from the data store. It is recommended that the data is backed up before proceeding with these steps.
  1. Run the Windows Command Prompt as an administrator.
  2. Navigate to the ArcGIS Data Store utilities folder located at:
C:\Program Files\ArcGIS\DataStore\tools
  1. Run the unregisterdatastore command utility to unregister the relational data store using the following command:
 unregisterdatastore.bat –stores relational –prompt yes
  1. Uninstall ArcGIS Data Store.
  2. Navigate to the following directory on the machine:
  1. Rename or delete the contents in the DataStore folder.
C:\
  1. Rename or delete the contents in the arcgisdatastore folder.
  2. Reinstall ArcGIS Data Store.
  3. Navigate to the Data Store Configuration Wizard for the primary ArcGIS Server machine, and re-register the primary Data Store. The following is an example of the Data Store Configuration Wizard directory:
https://datastoremachine.domain.com:2443/arcgis/datastore
Article ID: 000023168
Software:
  • ArcGIS Data Store
  • Portal for ArcGIS
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
